Changing interface 5 minute input rate
mcardell
I am not able to find the command to set the input rate average calculation on the interface.
I used the command once, but I have lost the reference to the documentation.
Can anyone help me?
I need to monitor the output in the interface for a period of less than the default 5 minutes.
Really thanks
Matteo
5 Replies 5
ctrieu
The command you need is "load-interval x" where x is the time value is sec.
Chinh
Really thanks
Matteo
Hello Team,
I am unable to config this command "load-interval x" in cisco ISR-4431.
Actually i want to reduce input traffic rate from 5 minutes to 30 second. Please help
odd...which IOS version are you running ? The command has been around for a very long time...
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/interface/command/ir-cr-book/ir-l1.html#wp3196224596
Sanjay Shaw
In config mode, you need to check the select Interface, on which you want to configure the load-interval
Router(config-if)# load-interval 30
