Cisco 2503 router IOS problem
bavoseesink
Hi all i`m new here.
i hope that one of you can help me.
i have a 2503 router but there is no IOS on the router.
I think that the last owner had a remote server and with the IOS on the server.
This is what i see when i boot the router.
System Bootstrap, Version 5.2(8a), RELEASE SOFTWARE
Copyright (c) 1986-1995 by cisco Systems
2500 processor with 16384 Kbytes of main memory
No usable interfaces
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
IOS (tm) 3000 Bootstrap Software (IGS-RXBOOT), Version 10.2(8a), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-1995 by cisco Systems, Inc.
Compiled Tue 24-Oct-95 15:46 by mkamson
Image text-base: 0x01020000, data-base: 0x00001000
cisco 2500 (68030) processor (revision D) with 16380K/2048K bytes of memory.
Processor board serial number 02986054 with hardware revision 00000000
X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
ISDN software, Version 1.0.
1 Ethernet/IEEE 802.3 interface.
2 Serial network interfaces.
1 ISDN Basic Rate interface.
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Loading network-confg ... [timed out]
Loading 2503b-confg ... [timed out]
Press RETURN to get started!
2503B(boot)>
Now is my problem, how do i upload new IOS into the router?
I can not use the serial interface.
I can not use the Bri (isdn) interface.
I can not use the AUX interface
wel.... i`m running out of options
is there some one ho can help me with this problem.
ps ....Sorry for my poor english
5 Replies 5
Kevin Dorrell
Level 10
Level 10
It may be just a question of the config register. Go into enable mode and do a show version. Is the config register 0x2102? Do a show flash as well. Do you see any files?
Kevin Dorrell
Luxembourg
it looks like your only option is to upload an IOS to flash with the xmodem command.
Check this link, it explains the procedure (obviously you do need an IOS on your laptop or PC):
Installing the Router Software by Using the Console or Auxiliary Port
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/prod_release_note09186a0080081127.html#5607
HTH,
GP
wel if i se command show flash
i have 16 megs free so there is on IOS image.
and the command xcopy is not anvalable in the command
the only copy options i have is
2503B(boot)#copy ?
erase Erase flash memory
flash Copy file from system flash
flh-log Copy FLH log file to server
mop Copy from MOP server
rcp Copy from a rcp server
running-config Copy current configuration
startup-config Copy startup configuration
tftp Copy from a TFTP server
verify Verify checksum of flash memory file
@gpauwen
wel i read the PDF you give me
but there is no clear explanation how to use auxiliary Port, if i plug a RJ45 in it an in the computer the computer says not connected.
wel i dont hope that i can throw this router away
i look fot the config file
the config register is set to 0x2102
404 error.  page not displayed
