Cisco IOU terminal logging does not appear in SSH session
davehouser1
I would like to see terminal logging output during an SSH session the same I would see when I am consoled into the device. What I mean by terminal logging is output to the terminal screen when events happen (OSPF neighbors connect, a port is disconnected, etc.)
I see this output when I am consoled into the device. However I do not see it in SSH.
How can I enable SSH to show terminal logging output?
Note: I am using Cisco IOU L3 Version 15.7(3)M2. And this is being run virtually in GNS3 2.2.22 via the ESXi appliance server.
 You need to enable it by running "terminal monitor" command.
By default only console session have logging enabled.
10 Replies 10
Ok, I turned on "terminal monitor".
I then consoled into the router, and SSHed into it as well.
Then I disconnected one of the router's interface.
Console shows terminal logging messages that the interface went down.
SSH connection does not show any info.
I reconnected
Console shows terminal logging messages that the interface went up.
How do I enable the same messages from console in my ssh session? (line vty 0 4)
We need more information to be able to identify your issue and to suggest solutions. Please post the output of these commands:
show log  (if the output is long the first couple of pages would be sufficient)
show run | include log
Rick
Hello @Richard Burts, here is what I found:
ios-isis-R2(config-if)#do show log
Syslog logging: enabled (0 messages dropped, 13 messages rate-limited, 0 flushes, 0 overruns, xml disabled, filtering disabled)
No Active Message Discriminator.
No Inactive Message Discriminator.
    Console logging: level debugging, 34 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging:  level debugging, 44 messages logged, xml disabled,
                    filtering disabled
    Exception Logging: size (4096 bytes)
    Count and timestamp logging messages: disabled
    Persistent logging: disabled
No active filter modules.
    Trap logging: level informational, 48 message lines logged
        Logging Source-Interface:       VRF Name:
Log Buffer (4096 bytes):
: http://www.cisco.com/techsupport
Copyright (c) 1986-2018 by Cisco Systems, Inc.
Compiled Wed 28-Mar-18 11:18 by prod_rel_team
*Jun 22 14:31:29.115: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Jun 22 14:31:29.121: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Jun 22 14:31:29.121: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Jun 22 14:31:29.840: %LINK-3-UPDOWN: Interface Ethernet0/0, changed state to up
*Jun 22 14:31:29.844: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up
*Jun 22 14:31:29.855: %LINK-3-UPDOWN: Interface Ethernet0/2, changed state to up
*Jun 22 14:31:29.860: %LINK-5-CHANGED: Interface Ethernet0/3, changed state to administratively down
*Jun 22 14:31:29.876: %LINK-5-CHANGED: Interface Ethernet1/0, changed state to administratively down
*Jun 22 14:31:29.884: %LINK-5-CHANGED: Interface Ethernet1/1, changed state to administratively down
*Jun 22 14:31:29.891: %LINK-5-CHANGED: Interface Ethernet1/2, changed state to administratively down
*Jun 22 14:31:29.896: %LINK-5-CHANGED: Interface Ethernet1/3, changed state to administratively down
*Jun 22 14:31:29.898: %LINK-5-CHANGED: Interface Serial2/0, changed state to administratively down
*Jun 22 14:31:29.902: %LINK-5-CHANGED: Interface Serial2/1, changed state to administratively down
*Jun 22 14:31:29.902: %LINK-5-CHANGED: Interface Serial2/2, changed state to administratively down
*Jun 22 14:31:29.906: %LINK-5-CHANGED: Interface Serial2/3, changed state to administratively down
*Jun 22 14:31:29.906: %LINK-5-CHANGED: Interface Serial3/0, changed state to administratively down
*Jun 22 14:31:29.909: %LINK-5-CHANGED: Interface Serial3/1, changed state to administratively down
*Jun 22 14:31:29.909: %LINK-5-CHANGED: Interface Serial3/2, changed state to administratively down
*Jun 22 14:31:29.914: %LINK-5-CHANGED: Interface Serial3/3, changed state to administratively down
*Jun 22 14:31:30.021: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
*Jun 22 14:31:30.844: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/0, changed state to up
*Jun 22 14:31:30.844: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to up
*Jun 22 14:31:30.856: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/2, changed state to up
*Jun 22 14:31:30.861: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/3, changed state to down
*Jun 22 14:31:30.881: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/0, changed state to down
*Jun 22 14:31:30.887: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/1, changed state to down
*Jun 22 14:31:30.891: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/2, changed state to down
*Jun 22 14:31:30.899: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet1/3, changed state to down
*Jun 22 14:31:30.899: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/0, changed state to down
*Jun 22 14:31:30.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/1, changed state to down
*Jun 22 14:31:30.903: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/2, changed state to down
*Jun 22 14:31:30.907: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial2/3, changed state to down
*Jun 22 14:31:30.907: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/0, changed state to down
*Jun 22 14:31:30.912: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/1, changed state to down
*Jun 22 14:31:30.912: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/2, changed state to down
*Jun 22 14:31:30.916: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial3/3, changed state to down
*Jun 22 14:31:34.895: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Jun 22 14:32:16.759: %LINK-5-CHANGED: Interface Ethernet0/1, changed state to administratively down
*Jun 22 14:32:17.764: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to down
*Jun 22 14:32:26.703: %LINK-3-UPDOWN: Interface Ethernet0/1, changed state to up
*Jun 22 14:32:27.707: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0/1, changed state to up
The above log output shows the time I `shut` E0/1 then `no shut` E0/1
ios-isis-R2(config-if)# do show run | i log
 logging synchronous
 login local
 logging synchronous
 logging synchronous
 login local
Not much context with the above command, including my running config just in case its needed:
2#show run
Building configuration...
Current configuration : 2417 bytes
! Last configuration change at 14:35:00 UTC Wed Jun 22 2022 by mruser
version 15.7
service password-encryption
hostname ios-isis-R2
boot-start-marker
boot-end-marker
enable password 7 ABC123ABC123DEF
no aaa new-model
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no ip icmp rate-limit unreachable
no ip domain lookup
ip domain name domain.internal
ip cef
no ipv6 cef
username mruser password 7 ABC123ABC123DEF
redundancy
ip tcp synwait-time 5
interface Loopback0
 ip address 172.16.10.1 255.255.255.255
interface Ethernet0/0
 ip address 192.168.0.52 255.255.255.0
 duplex auto
interface Ethernet0/1
 ip address 192.168.10.2 255.255.255.252
 ip router isis
 duplex auto
interface Ethernet0/2
 ip address 192.168.20.1 255.255.255.252
 ip router isis
 duplex auto
interface Ethernet0/3
 no ip address
 shutdown
 duplex auto
interface Ethernet1/0
 no ip address
 shutdown
 duplex auto
interface Ethernet1/1
 no ip address
 shutdown
 duplex auto
interface Ethernet1/2
 no ip address
 shutdown
 duplex auto
interface Ethernet1/3
 no ip address
 shutdown
 duplex auto
interface Serial2/0
 no ip address
 shutdown
 serial restart-delay 0
interface Serial2/1
 no ip address
 shutdown
interface Serial2/2
 no ip address
 shutdown
interface Serial2/3
 no ip address
 shutdown
interface Serial3/0
 no ip address
 shutdown
interface Serial3/1
 no ip address
 shutdown
interface Serial3/2
 no ip address
 shutdown
interface Serial3/3
 no ip address
 shutdown
router isis
 net 49.0010.1720.1601.0001.00
 summary-address 10.0.0.0 255.255.252.0
 passive-interface Loopback0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip ssh version 2
ipv6 ioam timestamp
control-plane
line con 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
 login local
line aux 0
 exec-timeout 0 0
 privilege level 15
 logging synchronous
line vty 0 4
 exec-timeout 0 0
 logging synchronous
 login local
 transport input ssh
end
ios-isis-R2#
Lastly version:
ios-isis-R2# show ver
Cisco IOS Software, Linux Software (I86BI_LINUX-ADVENTERPRISEK9-M), Version 15.7(3)M2, DEVELOPMENT TEST SOFTWARE
ROM: Bootstrap program is Linux
ios-isis-R2 uptime is 4 minutes
System returned to ROM by reload at 0
System image file is "unix:/opt/gns3/images/IOU/i86bi_LinuxL3-AdvEnterpriseK9-M2_157_3_May"
Last reload reason: Unknown reason
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Linux Unix (Intel-x86) processor with 76825K bytes of memory.
Processor board ID 2048028
8 Ethernet interfaces
8 Serial interfaces
64K bytes of NVRAM.
Configuration register is 0x0
Thank you. You have provided the output that I requested, and quite a bit of other good information. I would like to start with this part of the output
This shows that logging monitor is enabled. And logging monitor is what you need to get the logging output in your SSH session. I believe that @Flavio Miranda was on the right track to suggest using terminal monitor. You say that you turned on terminal monitor. I wonder if you correctly understood what was suggested. After establishing your SSH session, you issue the terminal monitor command in the SSH session. Is that what you did? If not then give it a try this way and let us know the results.
Rick
Ok I think I understand now. Yes @Flavio Miranda was right, need to run `terminal monitor` then I see the same output that the console shows for logging.
The problem was running `terminal monitor` then rebooting. I originally did run the command but rebooted, so I did not see output after reboot. So I needed to run the command again to see output.
Looks like `terminal monitor` is not a setting in the running config, so I don't believe it survives being volatile in memory after reboot.
I did find that if I go into the `line vty 0 4` there is a command "monitor" which I think does what I am looking for (enable terminal monitor after any SSH session is established). However after running it I see the following output
ios-isis-R2#line vty 0 4
ios-isis-R2(config-line)#monitor
VTY must be active
VTY must be active
VTY must be active
VTY must be active
Here is a post about it but does not make sense to me, and I still get the errors. I tried disconnecting from SSH and running the command in console, running it in vty 0 only, and tried running in a separate SSH session. "VTY must be active" keeps happening.
How can I get `terminal monitor` to run automatically after any SSH session, and have the setting survive reboots?
Let me start with a few points and then I will answer the question that you ask.
First you should understand that terminal monitor is not a config command and will not show up in the running config.
Also you should understand that terminal monitor is an exec command. You enter it in an SSH (or telnet) session. It operates for the duration of that SSH session (unless you decide to terminate it using the command terminal no monitor). When your SSH session terminates the terminal monitor is no longer operative. So the next time you establish an SSH session you will need to use terminal monitor in that session.
Your question is "How can I get `terminal monitor` to run automatically after any SSH session, and have the setting survive reboots?" The answer is that you can not accomplish this. You will need to use the command in every SSH session in which you want to see the logging output.
Rick
@Richard Burts  thank you for the explanation and help.
I suppose the only other question I have is what does `monitor` do in my `line vty 0 4` do? Does it not automatically enable terminal monitor during each SSH session? I think the answer is "no" but I just want to make sure.
This is an interesting follow up question. In my response I made the point that terminal monitor was an exec command and not a config command. Apparently there is a config version of the command. I have not been familiar with that config command. What I am finding is that it apparently is the config equivalent of the exec command. According to this discussion you can only configure that parameter for a vty that has an active session. So I am not sure how useful it really is.
https://learningnetwork.cisco.com/s/question/0D53i00000KsyzmCAB/vty-must-be-active-?dtid=osscdc000283
Rick
Thanks Richard. Yes for whatever reason that command just does not work.
I will mark @Flavio Miranda as the correct answer for now.
