Cisco SFTP-10G-T-X compatibility with Nexus 9000 C93180YC-EX
sameerasripad
Dear Team,
We are planning to connect NIC1 and NIC2 interfaces of ISE C220M5 UCS server to Nexus 9000 C93180YC-EX switches. with Cisco SFTP-10G-T-X SFP.
The interfaces are detecting these SFP's but getting an error. I have also checked on the compatibility matrix and support guide.
Please find the below logs and errors:
Ethernet109/1/24
transceiver is present
type is SFP-10G-T-X
name is CISCO-METHODE
part number is SP7052-C
revision is A1
serial number is MTC270306NJ
nominal bitrate is 10300 MBit/sec
Link length supported for copper is 30 m
cisco id is 3
cisco extended id number is 4
2023 Apr 12 16:51:52 R-US-FY-022 %ETHPORT-5-IF_HARDWARE: Interface Ethernet109/1/24, hardware type changed to 10G
2023 Apr 12 17:10:27 R-US-FY-022 %ETHPORT-5-IF_ADMIN_UP: Interface Ethernet109/1/24 is admin up .
2023 Apr 12 17:10:27 R-US-FY-022 %ETHPORT-3-IF_XCVR_ERROR: Interface Ethernet109/1/24, doesn't support SFP-10G-T-X
2023 Apr 12 17:10:27 R-US-FY-022 %ETHPORT-5-IF_DOWN_ERROR_DISABLED: Interface Ethernet109/1/24 is down (Error disabled. Reason:Unsupported media-type or configuration)
6 Replies 6
balaji.bandi
what nexus Code running check the matrix and nexus OS requirement :
https://tmgmatrix.cisco.com/?tpid=961
BB
sameerasripad
Software
BIOS: version 07.69
NXOS: version 9.3(10)
BIOS compile time: 04/07/2021
NXOS image file is: bootflash:///nxos.9.3.10.bin
NXOS compile time: 7/8/2022 9:00:00 [07/08/2022 20:10:17]
i think that should work. as per the matrix
try different ports and asic see if that works ?
BB
Yes tried on it. Even connecting to another nexus 9k but no luck.
Cisco SFP-10G-T-X Module Support
Beginning with Cisco NX-OS Release 9.3(5), 10G BASE-T SFP+ (RJ-45) is supported on N9K-C93240YC-FX2, N9K-C93180YC-EX, N9K-C93180YC-FX and N9K-C93360YC-FX2 devices. This copper transceiver operates at 10G by default.
When you connect a SFP-10G-T-X device into a port, all the neighboring ports of this device must be either empty, or be connected to passive copper links only.
Default Port MappingDevice NamePort Map:
Cisco Nexus N9K-C93180YC-EX and N9K-C93180YC-FX >>PI/PE: 1, 4-5, 8-9, 12-13, 16, 37, 40-41, 44-45, 48
Cisco Nexus 9000 Series NX-OS Interfaces Configuration Guide, Release 9.3(x) - Configuring Basic Interface Parameters [Cisco Nexus 9000 Series Switches] - Cisco
I have not suggested to connect another nexus 9K
suggested to use different port or asic
Look at the configuration guide of 9.3 code :
https://www.cisco.com/c/en/us/support/switches/nexus-9000-series-switches/products-installation-and-configuration-guides-list.html
BB
