Cisco switches 6503 ATA cards not working
xargo
I have a Cisco switches 6503 with supervisor MSFC2, IOS version 12.2, pcmcia ATA card 64 Mb, rommon 7.1(1)..
File installed cat6000-sup2k8.7-2-2.bin
And when I try to copy the IOS in the ATA card, or format the ATA card:
Format slot0:
Or
Format disk0:
The switch can’t copy or format on the ATA card.
And that’s happened in 2 switches with 2 different Supervisor and different ATA cards.
Other think, When I type the show version, I can’t see information about the ATA cards.
What’s wrong?
the PN. is MEM-C6K-ATA-1-64=
That's
Happened when I try to format
Console> (enable) format disk0:
All sectors will be erased, proceed (y/n) [n]? y
Enter volume id (up to 31 characters): test
Format device disk0 failed (unknown device)Console> (enable)
Console> (enable) format slot0:
Unknown device mfg id (5d.75.ffffffea)error = -1
Format device slot0 failed (unspecified error)Console> (enable)
Console> (enable)
that's the
show version
PS2 Module: PWR-950-AC Serial #: ABC07496185
Mod Port Model Serial # Versions
1 2 WS-X6K-SUP2-2GE SAL0752R7UE Hw : 5.0
Fw : 7.1(1)
Fw1: 6.1(3)
Sw : 7.4(3)
Sw1: 7.4(3)
WS-F6K-PFC2 SAL0752R764 Hw : 3.4
2 16 WS-X6516-GBIC SAL0723EHCA Hw : 5.5
Fw : 6.3(1)
Sw : 7.4(3)
15 1 WS-F6K-MSFC2 SAL0749QBR6 Hw : 2.6
Fw : 12.1(19)E1
Sw : 12.1(19)E1
DRAM FLASH NVRAM
Module Total Used Free Total Used Free Total Used Free
1 131072K 58516K 72556K 32768K 7629K 25139K 512K 265K 247K
Uptime is 0 day, 0 hour, 45 minutes
Console> (enable)
Right now, I'm not sure that the switch had the good version of ronmon.
And I found some more:
if I remove the ATA card in hot. the router display the fact, and if I re-insert the card, the same happened
I removed the module 2. (faster than upgrade) and I still have the problem with the ATA card.
Many thanks
Software version 7.5(1). You are currently running 7.4(3). 7.6(5) is the way to go. You can dowload the file from
http://www.cisco.com/cgi-bin/tablebuild.pl/cat6000-sup
Prashanth Krishnappa
You need 7.5(1) or higher for your ATA card support
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/relnotes/ol_1982.htm#379543
Version 7.5(1) of what? There ara too much versions on the sh ver . I think the Fw : 7.1(1) is the ronmon version, and that version it' fine.
You mean Sw : 7.4(3), what is that version?
Many Thanks
