class-map and policy-map statments located in a cisco WS-
ccoletti
Hello Cisco ,
i have the below class-map and policy-map statments located in a cisco WS-C4506 running cat4000-i5s-m code,
can you tell me what they are used for?
any help would be greatly appreciated.
Thank you
Charlie
class-map match-all cm_att_forward_class3
match access-group name al_att_forward_class3
class-map match-all cm_att_class1
match access-group name al_att_class1
class-map match-all cm_att_class4
match access-group name al_att_class4
class-map match-all cm_att_voip_return_class2
match access-group name al_att_voip_return_class2
class-map match-all cm_default_class4
match access-group name al_default_class4
class-map match-all cm_att_voip_forward_class2
match access-group name al_att_voip_forward_class2
class-map match-all cm_att_data_forward_class2
match access-group name al_att_data_forward_class2
class-map match-all cm_att_return_class3
match access-group name al_att_return_class3
class-map match-all cm_att_data_return_class2_user
match access-group name al_att_data_return_class2_user
class-map match-all cm_att_data_return_class2_server
match access-group name al_att_data_return_class2_server
policy-map pm_default_classes
class cm_default_class4
set ip dscp 0
policy-map pm_att_classes_voip_data
class cm_att_class1
set ip dscp 46
class cm_att_voip_forward_class2
set ip dscp 26
class cm_att_data_forward_class2
set ip dscp 26
class cm_att_forward_class3
set ip dscp 18
class cm_att_voip_return_class2
set ip dscp 26
class cm_att_data_return_class2_server
set ip dscp 26
class cm_att_data_return_class2_user
set ip dscp 26
class cm_att_return_class3
set ip dscp 18
class cm_att_class4
set ip dscp 0
Prashanth Krishnappa
Charlie
Looks like you are using class-maps to identify traffic based on access-lists and then using policy maps to mark dscp to a certain value.
Hope this helps.
