Configuration required in Cat 4006 to forward errors to syslog server
raju
I have setup a Kiwi syslog server. I want to configure in my Cat 4006 switch to forward the following messages to my syslog server
1. configuration changes
2. Vlan creation /modification
3. Power supply failures/module failures/temperature
4. When the processor utlization exceeds more than 75% , it should send a alert message to syslog server
5. Switch restart
6. Trap for any changes in Uplink ports only. There are 4 uplinks to other Switches from 4006. If any problem with these ports (uplink), it should send message to syslog server , not for all ports
Thanks in advance
Raju
spremkumar
Level 9
Level 9
I feel this link will be of some help to u in configuring different severity levels for different facilities available.
http://www.cisco.com/en/US/partner/products/hw/switches/ps663/products_configuration_guide_chapter09186a00800d81c8.html
By default for abnormal temp conditions u will get logs in the syslog server if u have already pointed the logs to the syslog server..
regds
Thanks edwin. It was a useful link.
Raju
FSS
