Configuring DHCP on 2522(help)
imran_mcse
I want to configure my Cisco 2522 Series router as a DHCP Server for the network. But when i tried to do that there are no commands available for this. Pls tell me how can i do this.I m using 12.0(5) OS in it.
Pls help.
to my best knowledge, you need at least IOS version 12.0(1)T, can you try and load that ?
Georg
I think it will not be the matter(as for my information). I think we can use on 12.0 IOS. pls will u provide detailed help on this issue.
you need to see the command option:
Router(config)#ip dhcp pool
if not, you have the wrong IOS. 12.0(1)T has the command.
HTH,
Georg
thanx dear georg. It has not . I m really thank ful to u on this cooperation. Thanx again.
