Connect Cisco 1605 to Comcast @home Cable modem
bbutler3295
Having some config problems, can not seem to get it to work i have a 1605 Cisco router, and i would like to use it to connect my lan to the cable modem is it posible without extra hardware, if so what hardware would i need.
difs
1) What version of software do you have (Show version)
2) Do you have a static IP or a dynamic IP?
3) Does your ISP require PPPOE?
4) What is your configuration (Show Run)
1. Version 12.0(3)T
2. Dynamic IP, but i do recall specifying the ip, and it still working.
3. No PPPOE Required
4. as far as the configureation i have specified one internal address of 192.168.1.1 255.255.255.0, one extenal address of the isp.
hostname that the isp requires. ip default-gateway of the isp, ip name-server's ip domain-name, and a static route to isp.
Please let me know if you need any more info, or if you have any idea's.
Brian
It doesn't sound like you enabled NAT/PAT:
http://www.cisco.com/warp/public/cc/pd/iosw/ioft/ionetn/prodlit/1195_pp.htm
http://www.cisco.com/warp/public/556/nat-cisco.shtml
Try something like this:
interface Ethernet0
description Cable Modem Connection
mac-address 0008.a3f7.bd5d
! Some ISP's require you to register a MAC address. Make sure this is correct.
ip address dhcp
! If you can't issue the ip address dhcp command you need to upgrade IOS
! I think you need Version 12.1(2)T or better
! Don't use a static address if they require dynamic, this will cause problems
ip access-group 199 in
no ip proxy-arp
ip accounting output-packets
ip accounting access-violations
ip nat outside
no ip route-cache
no ip mroute-cache
ntp disable
no snmp trap link-status
no cdp enable
interface Ethernet1
description Internal Network
ip access-group 102 in
no ip proxy-arp
ip nat inside
no ip route-cache
no ip mroute-cache
ip nat inside source list 1 interface Ethernet0 overload
access-list 1 permit 192.168.1.0 0.0.0.255
access-list 199 deny icmp any any log
access-list 199 deny ospf any any log
access-list 199 deny eigrp any any log
access-list 199 deny rip any any log
access-list 199 deny ip 10.0.0.0 0.255.255.255 any log
access-list 199 deny ip 192.168.0.0 0.0.255.255 any log
access-list 199 deny ip 127.0.0.0 0.255.255.255 any log
access-list 199 permit ip any any log
bbutler3295
OK i have found out from previous posts that this version of Cisco IOS Cisco IOS Version 12.0(9) does not support dynamicly assigned IP's, so i will not be able to use this IOS to support my ISP, my router type is cisco 1605. My question is what version will support dynamicly assigned ip's, and where can i purchase a copy, what are my options, do i have to go directly to cisco.
Thanks in advance.
Brian
