connecting 1750 and 1700
mialbert
I have a cisco 1700 and 1750, both with T1 csu/dsu Wic's. I am connecting these via cross over cable and they are not connecting. I have also used a straight through cable as well. Assuming ip addressing is correct. Should these be able to work on a cat5 ethernet between these directly connected. Or do i need db60's to connect these. Thanks
Kevin Dorrell
Level 10
Level 10
Normally in service you would use a straight cable, but back-to-back I think you need crossed. What did your crossover cable look like? An Ethernet crossover is not suitable. Working from first principles, I think it will work with 1-4, 2-5, 4-1, 5-2.
http://www.cisco.com/en/US/products/hw/routers/ps214/products_tech_note09186a00801f5d89.shtml#cables
Kevin Dorrell
Luxembourg
