connecting to ftp on another port
carl_townshend
on my router have have done a translation for port 100 outside to 21 inside for my ftp, my question is how do people on the outside connect to this, as surely outside it will be looking for port 21 ?
andrew.burns
Level 7
Level 7
For this to work you need to do two things:
1) Tell people that your ftp server is listening on a non-standard port (100 in this case)
2) Use an FTP client which supports connecting on a non-standard port (some do, some don't)
Andrew.
gpulos
Level 8
Level 8
also, if you're using a PIX, you should create a FIXUP for the port/protocol required. this will allow the firewall to listen to FTP on the specified port.
see these links for more info:
http://www.ciscotaccc.com/kaidara-advisor/security/showcase?case=K16700105
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/cmdref/df.htm#wp1067379
ariazk
if this ftp publicly available and u cant tell everyone then i think u need to reverse your configuration means outside 21 to redirect 100 inside.
