Connection between Distribution and DMZ switches
Hello all. I have a question about the enterprise network design. I have changed my job and here i have seen a couple of new design implementation which was done by previous worker. I do not have to much experience so i haven`t seen so much enterprise networks. I mostly worked in ISP. Here, we use 3750 swtiches stacked as Core-Distribution then Access switches. Moreover, we have 2 Nexus switches which are working as DMZ switches. The unusual thing for me is that Nexus switches and Core-Distribution switches are directly connected by L3 and L2 channels. So workers and users get to ASA trough DMZ Nexus switches but not directly from Core-Distribution switches. I have searched and https://www.cisco.com/c/en/us/td/docs/solutions/Enterprise/Security/IE_DG.html here in Figure 8 it also designed similarly. I did not understand what is pros of this design. Previously, in out projects we always separated DMZ and Internal switches and no direct connection. Sometime used some L2 direct connection to WAN switch for L2 Data channels from providers but having L3 connection between these switches...
Hope someone will clarify this...
Thanks in advance!
balaji.bandi
General in design you need to separate the DMZ switches with FW between Core and DMZ.
so that Core network protected from External connection.
BB
