04-29-2005 12:55 AM - edited 03-02-2019 10:36 PM
Hi there,
I have a weird case here...I could not ping my 6509 switch's layer 2/supervisor module although it is still up and running. Any ideas on this?
Thanks.
04-29-2005 01:17 AM
You should provide more detailed info to pinpoint the issue. This could be anything:
-IP adress / subnetmask mismatch
-Routing issues
-Access-lists
-..you name it
05-03-2005 05:48 PM
What CAT OS are you running? See if you can console in and see the same symptoms as in the following bug
http://www.cisco.com/cgi-bin/bugtool/onebug.pl?bugid=CSCed38989
05-03-2005 06:20 PM
thanks for your reply. I am now able to ping my switch after rebooting it. :)
05-03-2005 06:30 PM
If it is due to CSCed38989 you will see this problem again after about 7 months. So make sure your CAT OS is past this bug.
