CRC Errors
jp0801
Most of our servers that are connected to a Cisco 3548 Switch are seeing extreme amounts of CRC errors, but I am not seeing any errors on the interfaces or uplink interfaces of this switch. Installed a new switch and moved some of the servers to this switch and the problem was fixed. All connections on NIC's and Swicth are set to 100 FULL.
I don't understand why I didn't see these CRC errors on the old switch. Any Ideas!!
Thanks in Advance
steven-dunn
With full duplex operation the possibillity exists for data moving in one direction to contain errors and the reply data is fine ? This could explain why you were not seeing errors on the switch but on the servers.
The problem may have been resolved by new physical connections into the new switch ?
