12-15-2004 08:15 AM - edited 03-02-2019 08:36 PM
I have a LAN with 3 vlans on a catalyst 6509 routed by MSFC. On vlan 1 I have a DHCP server and on other 2 vlans (192, 194) clients. I configured "ip helper-address" command with dhcp's IP address. If I put a client on vlan 194 I get right IP address. If I move to vlan 192 I obtain same IP address of vlan 194 scope.
In the traces I see an error message:
there is no address pool for 10.155.192.191
IP addresses on MSFC are:
VLAN 192 : 10.155.192.190
VLAN 194 : 10.155.194.191
Anyone has an idea?
12-15-2004 08:41 AM
Are these all class C subnet masks ?
Have you defined the scopes properly?. To start with I would like to take a look at your DHCP configs as well as interface vlan configs for vlans 194 and 192..
12-15-2004 02:03 PM
Hi, all the subnets are /23 (255.255.254.0)
It seems that all scopes are defined OK because I can get right IP addresses from vlan 194 and if I delete lease entry also from 192.
I send to you the Interface vlan configs as soon as possible.
Thank you.
12-16-2004 01:58 AM
here's the config:
interface Vlan192
ip address 10.155.192.191 255.255.254.0
ip helper-address 10.155.201.21
no ip redirects
standby 192 priority 210 preempt
standby 192 ip 10.155.192.2
interface Vlan194
ip address 10.155.194.191 255.255.254.0
no ip redirects
standby 194 priority 200 preempt
standby 194 ip 10.155.194.2
12-16-2004 02:22 AM
Your Cisco config looks fine.
I belive you need to be using superscopes on your DHCP server for it to assign address to hosts from multiple network IDs
You can also use netmon on the DHCP server to gather some network traces of the DHCP pakcets or create an access-list on the MSFC similar to
access-list 187 permit udp any any eq bootps
access-list 187 permit udp any any eq bootpc
debug ip packet detail 187
You may need to turn off CEF on your VLAN interfaces to see the results
PD
12-16-2004 07:00 AM
Hi, you are the best!!!
I solved the problem I created a superscope for each vlan and now works fine.
Thank you very mutch.
12-17-2004 07:25 AM
no problem :)
Rgds
Paddy
