12-21-2004 12:13 PM - edited 03-02-2019 08:43 PM
Greetings,
I would like to verify that a 4506 with a supervisor IV running 12.2.20EWA code supports DHCP relay. According to the Software Configuration Guide for this level of code, DHCP Snooping is supported as well as an on-board DHCP server but I can not find a specific reference to DHCP Relay being supported. Shall I assume that because DHCP relay is documented in the generic IOS manuals that it is supported on the 4500 platform? I am probably being paranoid but I don't like surprises.
Thanks for any advice you can offer.
jb
Solved! Go to Solution.
12-21-2004 12:17 PM
Yes.. DHCP relay is supported. It is in list of supported features in the release notes
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat4000/relnotes/ol_5184.htm#wp483166
Just do a Edit, find for relay in your browser.
12-21-2004 12:17 PM
12-21-2004 02:01 PM
I feel MUCH better!
jb
