Does switch module (NM-16ESW) supported by Cisco 2610XM?
zsedc
The problem is: software.
NM-16ESW on 26xx series supported only by 12.2(2)XT.
Am I wrong here?
2610XM support added in 12.2(8)T1.
Am I wrong here?
So, is there NO software can work with this combination?
Then why it said that 2610 & 2610XM have same supported module list?
donewald
Level 6
Level 6
NM-16ESW is supported on the XM platforms in all the following code versions:
12.2(2)XT, 12.2(8)T1, 12.2(11)YT
Should work fine. Hope this helps you,
Don
12.2(2)XT (IP PLUS) stops after:
X.25 software, Version 3.0.0.
16 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
No onboard fastethernet, no WIC-1T
12.2(8)T1 (IP only) works fine but no 16ESW
%PA-2-UNDEFPA: Undefined Port Adaptor type 2A9 in bay 1
12.2(15)T (is io3 j) same as above
Now I've found document where said that 12.2(2)XT is only release with
NM-16ESW support.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_mod/cis2600/hw_inst/nm_inst/nm-doc/ovrnetm.htm
Table 1-1:
16-Port Ethernet Switch
Specific Limited Lifetime: 12.2(2)XT
First "T" (Technology): None
First Mainline: None
Am I understand it wrong?
Or may be this document outdated?
