Ethernet cable pairs
Hello Everyone,
I know two wires are used to send data and two wires for receiving in10M Base and 100M Base Ethernet cable., but why two wires? Data are sent on two wires at the same time?
You can refer below for details:
http://www.cisco.com/c/dam/en/us/support/docs/routers/10000-series-routers/46792-eth-cross-cable-pin-hub.gif
Basically UTP caries digital signals i.e. 0 and 1. for each TX and RX both have + and - i.e. TX+ and TX- at both end. + denotes 1 and - denotes 0. So tatal 4 wires.
Thanks for your accurate answer.
