09-09-2014 03:51 AM - edited 03-03-2019 07:35 AM
For Multlink interface ,MTU size is set to 1500,but able to ping upto 9000.How???
Multilink is bundle of 2 E1 in chanellized STM-1
09-09-2014 04:48 AM
is the DF flag set?
-Jonathan
09-09-2014 05:17 AM
Thanks Jon
On Multilink , fragment is disable....
Is this is the reason ???/
09-09-2014 05:43 AM
Ah not sure - just to verify, are you setting the DF bit on your ping and testing that way?
-Jonathan
09-09-2014 08:29 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
No, that's a PPP option.
As Jonathan has asked, are you setting DF in your ping? If not, ping will allow larger than MTU, it will just fragment the IP packet.
09-10-2014 03:49 AM
Hi Josheph , How PPP is support for Jumbo ping....?
09-10-2014 04:13 AM
Disclaimer
Posting
It's not PPP, it's IP that does.
Again, try setting DF and see if it works.
However, if you're just ping across the PPP link, often serial media used with PPP supports MTUs larger than Ethernet.
