Found problems finding Cisco Web Interface SW
agarrido
Hi, I was looking for a piece of SW.
I got a Catalyst 4000 that doesn´t have the cv file on the flash directory. I supposed that it should be on the SW package that came with the switch, but...who knos where it is now.
Anyhow, I´m looking for this:
cat4000-cv.6-3-3.bin
Can somebody give me the link to it?
rmushtaq
Level 8
Level 8
You can get the cv image from:
http://www.cisco.com/cgi-bin/tablebuild.pl/cat4000
Here's the etch tip that describes on how to use/configure the buitl in CV for Cat4000:
http://www.cisco.com/warp/public/473/105_15954.shtml.
Can I use a cv version of 6.3.2a if I have a SW version 6.3.3?
I´m not quite sure of it, and I can not find the exact version.
thankx
You can use 6.3.3, but I'd suggest that you first go through the Release Notes of this version and also consult with your local Cisco ANS Engineer before doing an upgrade. That way you'll know of any known issues ahead of time. Since, I don't know about your network, I cannot make any code recommendations here. Also, it'll be better to first try the new code on a lab/test switch for evaluation before using it on a production switch.
