Frame Relay Issues, plus some misc. questions.
mikejr
First, let me say thanks to anyone who is going to help.
Alright, to the nitty-gritty, I have two 56k routers w/56 CSU/DSU cards in them connected back to back with a rollover cable. I don't believe the rollover plays a roll in this problem, becuase I have CD lights on both the routers.
I am new to dealing with routers, but the goal I'm trying to achieve is to link two stores with frame. I believe most of my configuration is correct, but I cannot get the line protocols to come up on the frame. Below should be most or all of the information you need. One last thing -- as I said, I'm new so if you guys see something that may not necessarily be applicable to my problem, I'd appreciate it if you brought it to my attention.
SHOW CONFIGURATION
Using 1063 out of 7506 bytes
version 12.0
service config
hostname Kittanning
ip subnet-zero
interface Ethernet0
ip address 172.16.96.101 255.255.255.0
no ip directed-broadcast
no cdp enable
interface Serial0
no ip address
encapsulation frame-relay
logging event subif-link-status
logging event dlci-status-change
interface Serial1
no ip address
service-module 56k clock source internal
interface Serial1.1 point-to-point
ip address 10.0.1.2 255.255.255.0
frame-relay interface-dlci 17
router eigrp 202
network 192.163.123.0
ip classless
SHOW FRAME PVC
PVC Statistics for interface Serial0 (Frame Relay DTE)
PVC Statistics for interface Serial1 (Frame Relay DTE)
DLCI = 17, DLCI USAGE = LOCAL, PVC STATUS = DELETED, INTERFACE = Serial1.1
input pkts 3 output pkts 0 in bytes 1824
out bytes 0 dropped pkts 3 in FECN pkts 0
in BECN pkts 0 out FECN pkts 0 out BECN pkts 0
in DE pkts 0 out DE pkts 0
out bcast pkts 0 out bcast bytes 0
pvc create time 00:28:12, last time pvc status changed 00:27:33
SHOW INT S1
Serial1 is up, line protocol is down
Hardware is QUICC Serial (with 56k 4-wire CSU/DSU WIC)
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec, rely 254/255, load 1/255
Encapsulation FRAME-RELAY, loopback not set, keepalive set (10 sec)
LMI enq sent 181, LMI stat recvd 0, LMI upd recvd 0, DTE LMI down
LMI enq recvd 269, LMI stat sent 0, LMI upd sent 0
LMI DLCI 1023 LMI type is CISCO frame relay DTE
Broadcast queue 0/64, broadcasts sent/dropped 0/0, interface broadcasts 0
Last input 00:00:02, output 00:00:02, output hang never
Input queue: 0/75/0 (size/max/drops); Total output drops: 0
Queueing strategy: weighted fair
Output queue: 0/1000/64/0 (size/max total/threshold/drops)
Conversations 0/1/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
275 packets input, 5399 bytes, 0 no buffer
Received 1 broadcasts, 0 runts, 0 giants, 0 throttles
47 input errors, 0 CRC, 43 frame, 0 overrun, 0 ignored, 4 abort
272 packets output, 3575 bytes, 0 underruns
0 output errors, 0 collisions, 61 interface resets
125 carrier transitions
DCD=up DSR=up DTR=up RTS=up CTS=up
MY OTHER QUESTIONS
What is causing these annoying errors and how can I fix them?
%Error opening tftp://255.255.255.255/cisconet.cfg (Timed out)
%Error opening tftp://255.255.255.255/kittanning-confg (Timed out)
%Error opening tftp://255.255.255.255/kittanni.cfg (Timed out)
Also, the address I supply to the Frame sub interface is just for connection between the two routers, correct? And the same thing for the DLCI, I don't understand why I need another IP address for that.
The routing I'm trying to set up is just one network address. 192.163.123.0. Can both stores be on the same network address? Or do I need something like this: Store 1 - 192.163.123.xxx, Store 2 - 192.163.124.xxx.
Well thanks again for the help, I know it's alot of questions, I just hope someone can help me some =)
--Mike
MickPhelps
First: "no service config" will stop the errors.
2nd: I think you'll have a tough time with frame-relay back to back over 56K internal CSU/DSUs. The key is to enable "frame-relay switching" in global config on the router that is supplying clocking, and then "frame-relay intf-type dce" on the main serial interface (not the sub-if).
The problem is, I don't know if a WIC 56K CSU/DSU will accept that last command, but give it a shot.
3rd: You'll have to set up both stores on seperate IP addresses unless you plan on bridging rather than routing. I suggest stronly that you route.
The IP addresses for the sub-ifs can be "ip unnumbered ethernet0" to save IP space.
Mick.
What he said and, Frame switching requires at least a plus level IOS.
