09-10-2012 04:49 AM - edited 03-03-2019 06:45 AM
Hi All,
I have configured below point to point link with FR switch in GNS 3.
below is the configuration for the senario.
R1#sh run int serial 0/0
Building configuration...
Current configuration : 144 bytes
interface Serial0/0
no ip address
encapsulation frame-relay
clock rate 2000000
no frame-relay inverse-arp
frame-relay lmi-type ansi
end
R1#sh run int serial 0/0.101
Current configuration : 118 bytes
interface Serial0/0.101 point-to-point
ip address 10.1.1.1 255.255.255.252
frame-relay interface-dlci 101
end
R2#sh run int serial 0/0
interface Serial0/0
no ip address
clock rate 2000000
end
R2#sh run int serial 0/0.201
interface Serial0/0.201 point-to-point
ip address 10.1.1.2 255.255.255.252
frame-relay interface-dlci 201
end
FR switch is port 1-101 for R1 serial 0/0 & Port 2-201 for R2 serial 0/0
Below is the status for the sh frame-relay map
R1#sh frame-relay map
Serial0/0.101 (up): point-to-point dlci, dlci 101(0x65,0x1850), broadcast status defined, active
R2#sh frame-relay map
Serial0/0.201 (down): point-to-point dlci, dlci 201(0xC9,0x3090), broadcast status deleted
Serial0/1.201 (administratively down): point-to-point dlci, dlci 201(0xC9,0x3090), broadcast status deleted
Please let me know where i am making a mistake.
09-10-2012 05:27 AM
can you do a no shut on the s0/0 of R2
Regards.
Alain
09-10-2012 05:35 AM
Hi Alain,
I did no shut but still the result is the same
status deleted
Amol
05-06-2013 12:21 PM
Double check, that you have entered correct DLCI.
05-14-2013 07:20 AM
Hello
You mentioned a FR switch, if so these routers interfaces should not be clocking - as they should be both DTE's
Delete the config (sub interfaces and default the serial interfaces ,also shut/no shut them and re apply the config)
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
05-14-2013 12:20 PM
I would also suggest looking for an error in the DLCI assignment and DLCI routing on the frame relay switch.
Rick
