06-27-2004 01:58 PM - edited 03-02-2019 04:39 PM
If I have frame relay traffic shaping configured on a Frame Relay interface, when does the shaping kick in? Is it once the CIR is reached, or before that? The reason I ask is because I have it enabled in a 1.5MB interface, with a 768K CIR, but the according to my network management station the interface is only running at 500K/sec, and the interface is periodically saying the shaping is active.
Colin
06-27-2004 03:40 PM
Depends on your config. (adaptive-shaping, etc.) Could you post the relavent parts of your running.
06-27-2004 05:50 PM
Here is a cut of the config:
interface Serial1/0
mtu 1500
no ip address
encapsulation frame-relay IETF
no ip mroute-cache
load-interval 30
dsu bandwidth 44210
framing c-bit
cablelength 5
serial restart_delay 0
frame-relay class default
frame-relay interface-queue priority
interface Serial1/0.107 point-to-point
bandwidth 1920
ip address 192.168.195.46 255.255.255.252
no ip mroute-cache
no cdp enable
frame-relay class video1920
frame-relay interface-dlci 356
interface Serial1/0.108 point-to-point
bandwidth 1920
ip address 192.168.195.50 255.255.255.252
no ip mroute-cache
no cdp enable
frame-relay interface-dlci 357
map-class frame-relay default
frame-relay adaptive-shaping becn
frame-relay cir 1920000
frame-relay bc 240000
frame-relay be 19200
frame-relay fair-queue
map-class frame-relay fast
frame-relay cir 10000000
frame-relay bc 1250000
frame-relay be 100000
map-class frame-relay video1534
frame-relay cir 1534000
frame-relay bc 15340
frame-relay mincir 1534000
frame-relay interface-queue priority high
map-class frame-relay video5000
frame-relay cir 5000000
frame-relay bc 50000
frame-relay mincir 5000000
map-class frame-relay video1920
frame-relay bc 19200
frame-relay mincir 1920000
map-class frame-relay video1408
frame-relay cir 1408000
frame-relay bc 14080
frame-relay mincir 1408000
map-class frame-relay video1024
frame-relay cir 1024000
frame-relay bc 12000
frame-relay mincir 1024000
