FTA2 Fan Module not working
cerickson111
I have a known good fan module that does not work when plugged into a 15454 Cerent chassis.  Any ideas on where to check first?  Pin-out of the connector on the back of the shelf possibly?
refer to the initial troubleshooting guide below:
http://www.cisco.com/c/en/us/td/docs/optical/spares/15454/sonet/guides/454fan.html
http://www.cisco.com/c/en/us/support/optical-networking/ons-15454-series-multiservice-provisioning-platforms/products-troubleshooting-guides-list.html
http://www.cisco.com/c/en/us/td/docs/optical/15000r9_1/15454/sdh/troubleshooting/guide/454e91ts.pdf
its already eos, so the rma would not be possible from tac. but you check it once for clarity.
regards,
-Do rate if it helps.
Thank you.     I found a spare daughter board that is wired to the fan module connector, and replacing it fixed the trouble.
