Ghosting Running Extremely Slow
lcoles
I'm ghosting from one PC to another. The PCS are on both on the same vlan. Yesterday I was doing the same thing and it took about 15 minutes. Today the ghosting application is stating it will take about 1 hour. There is nothing different today than yesterday. I'm fairly new at networking. What can I do to look at this traffic to see if I can figure out why this is running so slow? Any help would be appreciated. Thanks, Laurie Coles
cyberpete
GURANTEE IT IS A DUPLEX/SPEED SETTING ON THE PORT OR NUC CARD - ENSURE BOTTH ARE HARD CODED TO BEST SPEEDS - HOPEFULLY 100 FULL DUPLEX
zhouxiaoding
Check the speed and duplex, make sure both PC have the same configuration of that. Like speed 100 & duplex full.
lcoles
Thank you for the suggestion. After working on this all day it was discovered that a switch on the ghosting executable file needed to be turned on where it would use the computer's bios. We used to use this switch on computers a long while back. Now it seems the new Gateway computers that we are receiving must have this switch on. Thanks again for everyone's help. Laurie Coles
