Gigabit over fibre on a 3524 switch
tim
I am about to embark on connecting a single gigabit over fibre connection from a 3524XL switch to a 5505 switch. Do I need a specific spanning tree vlan cost, or is this irrelevant with a single connection?
bsivasub
Level 4
Level 4
You don't need it for single connection.
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat6000/sw_7_1/conf_gd/spantree.htm#xtocid2339740
Even if you connect multiple connections, default cost would take care for different media types (fastethernet/Gigabit)
Thanks for the response - I will now press ahead!
