GRE Tunnel Problem with same tunnel source
renemerki1
I have one Main location and 2 destination. I want to have 2 GRE tunnels one to each destination.
The Problem is, that one tunnel in the Main location does not come up. (up/down).
I've a Cisco CAT6500 at the Main location with 12.2(33)SXI4a.
When I create the new Tunnel i got following error:
%Warning: Using same source IP for more than one IP/GRE tunnels
%may cause %software switching packets for tunnels using
%this address. If possible, use a %unique tunnel source for
%Interface Tunnel20
noveukues03s(config-if)#end
The Tunnel 20 (red) will not come up. Any Idee how to solve this issue ?
I need the same tunnel source "vlan10"
MAIN:
interface Tunnel10
 ip address 192.168.10.1 255.255.255.252
 ip mtu 1476
 ip tcp adjust-mss 1430
 keepalive 1 3
 tunnel source Vlan10
 tunnel destination 10.163.82.129
interface Tunnel20
 ip address 192.168.20.1 255.255.255.252
 ip mtu 1476
 keepalive 1 3
 tunnel destination 10.162.64.6
end
Destination A
interface Tunnel10
 ip address 192.168.10.2 255.255.255.252
 no ip redirects
 ip mtu 1476
 load-interval 30
 keepalive 1 3
 tunnel source Vlan118
 tunnel destination 10.166.8.10
Destination B
interface Tunnel20
 ip address 192.168.20.2 255.255.255.252
 no ip redirects
 ip mtu 1476
 keepalive 1 3
 tunnel source Vlan64
thanks
René
Richard Burts
Rene
The message that you get is informational and warns that there may be a performance impact if you configure two GRE tunnels which use the same source address. I do not believe that this has anything to do with the result that the second tunnel is up/down. I suspect that the up/down result is because the keepalives are failing between your 6500 and the device at destination B. As a test of that theory you could remove the keepalives configured for tunnel 20. If you do that I suspect that the tunnel will become up/up.
But up/up does not necessarily mean that the tunnel is working or will pass two way traffic. As the next step I would ask that you attempt from the 6500 to ping 10.162.64.6 sourcing the ping from vlan 10. And from destination B try to ping 10.166.8.10 sourcing the ping from vlan 64.
Try these and let us know the results.
Rick
Rick
Hi Richard,
Yes this was the problem. Removing keepalives helps.
I've also moved the GRE to a "Router" behind the Cat 6500. but same effect. one Site GRE "up/down".
I've already tested extended pings between the "tunnels" before that works all the time.
Now all works fine. (no keepalives)
Many thanks
René
Rene
Moving the GRE from the 6500 to a router will certainly address the potential performance issue. I am glad that my suggestion about removing keepalive was helpful.
Rick
Rick
