Help Basic term?
imran_mcse
I want to know that What is the difference between Access layer,distribution layer and core layer devices.
Pls mention me what is difference between all these types of layers. in detail pls.
rais
Level 7
Level 7
In a hierarchical network design, you usually have three levels (you dont have to have all three) of networking gear.
Access is for connecting to the network. Like the switch your PC connects to. This layer is mostly most secured.
Distribution is the layer that connects many access devices together. If the network is huge you can see multiple distribution layers. If network is small, you may not see it at all.
Core is where you have all your distribution connect to. Usually you have little or not security at this layer. it is meant to switch packets as fast as it can.
HTH.
sjallaluddin
HI,
You can find you answer on the Cisco.com site it self. Look for Documents in Technologies section.
SKJ
