12-17-2010 01:03 AM - edited 03-03-2019 06:09 AM
Hi There, I am very new to Cisco and am interested in learning how to program up some devices. I have a Cisco SR520 Wireless ADSL Router and am trying to configure it using the Device Setup Wizard in the Cisco Configuration Assistant Software.
I get to step 5 of 10 and it is asking for a Username and Password - Message goes like this -
'Please enter your username and password for realm "Admin" on "Site Name"
I have tried everything I can think of including, cisco/cisco, Cisco/Cisco, nothing at all, admin/admin etc etc
Can anyone help me out on this?
Regards...Will
08-01-2011 08:43 AM
Hello William,
I run exactly into the same problem, did you find the solution?
RGDS,
Pascal.
12-19-2011 07:48 AM
i was hoping for an update on this as well. Someone out there needs to know something.
12-19-2011 10:12 AM
Since device runs an IOS which is support by the enterprise group please repost this question on their support forum. This is most likely the reason you haven't received a response from on this post.
Jasbryan
12-19-2011 11:28 AM
Hi William,
Which SR520 do you have?
The only SR520 product ID number that falls under the Small Business umbrella is the SR520-T1-K9.
However if you have the SR520-FE product, that is supported by Cisco TAC not SBSC. The area that your question should be posted at is this area within the support communitywhich I can help you move your post to so you don't have to repost it.:
https://supportforums.cisco.com/community/netpro/network-infrastructure
Cindy Toy
Cisco Small Business Community Manager
for Cisco Small Business Products
www.cisco.com/go/smallbizsupport
twitter: CiscoSBsupport
