Help for creating a scenario
sudeesh79
Please help me to create a scenario.
I have a Switch.It consists of three VLANS,Vlan1,
Vlan2 and Vlan3.I want to connect a server in this
switch.The vlans are not able toping each other,but
all the vlan members should be able to access the
server.how is it possible.
please suggest
thankx
Sudhi
Hi, Sudhi,
the easiest way is to use a router or an internal routing engine on your switch and route between your vlans.
Another thing might be to use PVlans. An explanation and configuration will u find in the following links.
http://www.cisco.com/en/US/tech/tk389/tk814/tk840/tsd_technology_support_sub-protocol_home.html
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_guide_chapter09186a00800dde94.html
Hope this is of any help.
Sebastian
gwes
You might also consider using a trunk connection to your server. That way you don’t have to buy a router. Please bear in mind that the server nic has to support ISL or IEEE 802.1q.
Interface fastethernet 0/1
Switchport trunk encapsulation (isl or iee 802.1q)
Switchport mode trunk
wkumari
The quick and dirty answer to this is to throw multiple NICs in the server and connect each NIC to each VLAN - it doesn't scale hugely well, but is very easy to implement.
A more elegant (but this depends on you comfort level with configuring switches) is to make a trunk port to the server and run 802.1q - keep in mind that this requires capable nics and all traffic to the server will be on one cable, so it is possible that you could see performance issues...
