Help ISR4331 not recognizing LTE card
achandra20147
Trying to bring up an ISR4331 that has 2 - LTE cards installed in it.
When I type LTERouter# show facility-alarm status, I see that the LTE cards which are installed in subslot 0/1 and 0/2 have a "Critical" alarm and in the description it says "Active Card Removed OIR Alarm [0]
Except the cards are installed in the chassis.
Any suggestions on what I should try next to activate these cards? Also, do I need a license to activate these LTE cards on the ISR?
Amrit
Raise a TAC Case.
There are no error messages displayed that points to a hardware failure.
This only leave a firmware bug.
9 Replies 9
Leo Laohoo
Console into the chassis and reboot.
Post the entire boot-up process.
Here is the info -
Initializing Hardware ...
Checking for PCIe device presence...done
System integrity status: 0x610
Rom image verified correctly
System Bootstrap, Version 16.12(2r), RELEASE SOFTWARE
Copyright (c) 1994-2019 by cisco Systems, Inc.
Current image running: Boot ROM0
Last reset cause: LocalSoft
ISR4331/K9 platform with 4194304 Kbytes of main memory
Located isr4300-universalk9.17.04.01b.SPA.bin
Package header rev 3 structure detected
IsoSize = 710053888
Calculating SHA-1 hash...Validate package: SHA-1 hash:
calculated B156C8EB:4516A29F:964BB824:F7433EFB:28C1C904
expected B156C8EB:4516A29F:964BB824:F7433EFB:28C1C904
RSA Signed RELEASE Image Signature Verification Successful.
Image validated
Apr 8 14:04:45.621: %BOOT-5-OPMODE_LOG: R0/0: binos: System booted in AUTONOMOUS mode
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Bengaluru], ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 17.4.1b, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2021 by Cisco Systems, Inc.
Compiled Sat 06-Feb-21 02:03 by mcpre
This software version supports only Smart Licensing as the software licensing mechanism.
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
All TCP AO KDF Tests Pass
cisco ISR4331/K9 (1RU) processor with 1707017K/3071K bytes of memory.
Processor board ID FLM2242W116
Router operating mode: Autonomous
3 Gigabit Ethernet interfaces
4 Cellular interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
WARNING: Command has been added to the configuration using a type 7 password. However, type 7 passwords will soon be deprecated. Migrate to a supported password type
Warning: GigabitEthernet0 does not currently have an ip address
SETUP: new interface Cellular0/1/0 placed in "shutdown" state
SETUP: new interface Cellular0/1/1 placed in "shutdown" state
SETUP: new interface Cellular0/2/0 placed in "shutdown" state
SETUP: new interface Cellular0/2/1 placed in "shutdown" state
Press RETURN to get started!
*Apr 8 14:05:06.678: %LICENSE-6-EULA_ACCEPT_ALL: The Right to Use End User License Agreement is accepted
*Apr 8 14:05:06.930: %ISR_THROUGHPUT-6-LEVEL: Throughput level has been set to 100000 kbps
*Apr 8 14:05:10.154: %SMART_LIC-6-AGENT_ENABLED: Smart Agent for Licensing is enabled
*Apr 8 14:05:10.908: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowedESG-PM-ACL:[subsys-init] Init ESG-ACL subsystem starting
*Apr 8 14:05:13.207:
*Apr 8 14:05:16.570: BFD: brace register success
*Apr 8 14:05:29.114: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 8 14:05:30.887: %CRYPTO_ENGINE-4-CSDL_COMPLIANCE_DISABLED: Cisco PSB security compliance has been disabled
*Apr 8 14:05:31.656: %CUBE-3-LICENSING: SIP trunking (CUBE) licensing is now based on dynamic sessions counting, static license capacity configuration through 'mode border-element license capacity' would be ignored.
*Apr 8 14:05:31.665: %SIP-1-LICENSING: CUBE license reporting period has been set to the minimum value of 8 hours.
*Apr 8 14:05:31.817: %VOICE_HA-7-STATUS: CUBE HA-supported platform detected.
*Apr 8 14:05:35.078: %LINK-3-UPDOWN: Interface Lsmpi0, changed state to up
*Apr 8 14:05:37.251: %PNP-6-PNP_DISCOVERY_STARTED: PnP Discovery started
*Apr 8 14:04:45.541: %BOOT-5-OPMODE_LOG: R0/0: binos: System booted in AUTONOMOUS mode
*Apr 8 14:05:09.928: %FLASH_CHECK-3-DISK_QUOTA: R0/0: flash_check: Flash disk quota exceeded [free space is 883428 kB] - Please clean up files on bootflash.
*Apr 8 14:05:10.273: %CMRP_PFU-6-FANASSY_INSERTED: R0/0: cmand: Fan Assembly is inserted.
*Apr 8 14:05:11.817: %CMLIB-6-THROUGHPUT_VALUE: R0/0: cmand: Throughput license found, throughput set to 100000 kbps
*Apr 8 14:05:38.318: %LINK-3-UPDOWN: Interface EOBC0, changed state to up
*Apr 8 14:05:38.334: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Apr 8 14:05:38.662: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Apr 8 14:05:38.663: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to down
*Apr 8 14:05:38.699: %IOSXE_RP_ALARM-6-INFO: ASSERT CRITICAL GigabitEthernet0 Physical Port Link Down
*Apr 8 14:05:40.032: %LINK-3-UPDOWN: Interface LIIN0, changed state to up
*Apr 8 14:05:40.358: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi0, changed state to up
*Apr 8 14:05:40.358: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC0, changed state to up
*Apr 8 14:05:40.359: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Apr 8 14:05:41.116: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN0, changed state to up
*Apr 8 14:05:42.668: %SYS-5-CONFIG_P: Configured programmatically by process MGMT VRF Process from console as vty0
*Apr 8 14:05:43.488: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-intf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Apr 8 14:05:43.541: %SYS-5-CONFIG_P: Configured programmatically by process MGMT VRF Process from console as vty0
*Apr 8 14:05:44.037: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Apr 8 14:05:46.999: %SYS-7-NVRAM_INIT_WAIT_TIME: Waited 0 seconds for NVRAM to be available
*Apr 8 14:05:47.814: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named ssh-keys has been generated or imported by crypto config
*Apr 8 14:05:47.830: %SYS-6-PRIVCFG_DECRYPT_SUCCESS: Successfully apply the private config file
*Apr 8 14:05:47 UTC: %SYS-5-LOG_CONFIG_CHANGE: Buffer logging: level informational, xml disabled, filtering disabled, size (16000)
*Apr 8 14:05:48 UTC: %AAAA-4-CLI_DEPRECATED: WARNING: Command has been added to the configuration using a type 7 password. However, type 7 passwords will soon be deprecated. Migrate to a supported password type
*Apr 8 14:05:48 UTC: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TP-self-signed-1983262869 created succesfully
*Apr 8 14:05:48 UTC: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*Apr 8 14:05:48 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface Loopback0, changed state to up
*Apr 8 14:05:49 UTC: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 8 14:05:50 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0, changed state to up
*Apr 8 14:05:50 UTC: %IOSXE_RP_ALARM-6-INFO: CLEAR CRITICAL GigabitEthernet0 Physical Port Link Down
*Apr 8 14:05:50 UTC: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/0, interfaces disabled
*Apr 8 14:05:50 UTC: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/1, interfaces disabled
*Apr 8 14:05:50 UTC: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/2, interfaces disabled
*Apr 8 14:05:50 UTC: %SPA_OIR-6-OFFLINECARD: SPA (ISR4331-3x1GE) offline in subslot 0/0
*Apr 8 14:05:50 UTC: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/1 is DOWN
*Apr 8 14:05:50 UTC: %SPA_OIR-6-OFFLINECARD: SPA (NIM-LTEA-EA) offline in subslot 0/1
*Apr 8 14:05:50 UTC: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/2 is DOWN
*Apr 8 14:05:50 UTC: %SPA_OIR-6-OFFLINECARD: SPA (NIM-LTEA-EA) offline in subslot 0/2
*Apr 8 14:05:50 UTC: %IOSXE_OIR-6-INSCARD: Card (fp) inserted in slot F0
*Apr 8 14:05:50 UTC: %IOSXE_OIR-6-ONLINECARD: Card (fp) online in slot F0
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 0
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 0
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-INSCARD: Card (cc) inserted in slot 1
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-ONLINECARD: Card (cc) online in slot 1
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/0
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/1
*Apr 8 14:05:51 UTC: %IOSXE_OIR-6-INSSPA: SPA inserted in subslot 0/2
*Apr 8 14:05:51 UTC: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Apr 8 14:05:51 UTC: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Apr 8 14:05:51 UTC: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Apr 8 14:05:51 UTC: %SYS-5-RESTART: System restarted --
*Apr 8 14:05:51 UTC: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type tacacs+ (UNKNOWN)
*Apr 8 14:05:55 UTC: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named ssh-keys.server has been generated or imported by crypto-engine
*Apr 8 14:05:57 UTC: %PNP-6-PNP_BEST_UDI_UPDATE: Best UDI [PID:ISR4331/K9,VID:V04,SN:FLM2242W116] identified via (entity-mibs)
*Apr 8 14:05:57 UTC: %PNP-6-PNP_CDP_UPDATE: Device UDI [PID:ISR4331/K9,VID:V04,SN:FLM2242W116] identified for CDP
*Apr 8 14:05:57 UTC: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Apr 8 14:06:00 UTC: %SPA_OIR-6-ONLINECARD: SPA (ISR4331-3x1GE) online in subslot 0/0
*Apr 8 14:06:00 UTC: %DHCP-6-ADDRESS_ASSIGN: Interface GigabitEthernet0 assigned DHCP address 10.10.0.90, mask 255.255.255.0, hostname ciscoLTE
*Apr 8 14:06:01 UTC: %SYS-5-CONFIG_P: Configured programmatically by process EPM CREATE DEFAULT CWA URL ACL from console as console
*Apr 8 14:06:02 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to down
*Apr 8 14:06:09 UTC: %LINK-3-UPDOWN: Interface GigabitEthernet0/0/0, changed state to up
*Apr 8 14:06:10 UTC: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0/0, changed state to up
*Apr 8 14:06:12 UTC: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is OFF
*Apr 8 14:06:12 UTC: %CRYPTO-6-GDOI_ON_OFF: GDOI is OFF
*Apr 8 14:06:12 UTC: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI created succesfully
*Apr 8 14:06:12 UTC: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Apr 8 14:06:12 UTC: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI0 created succesfully
*Apr 8 14:06:12 UTC: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
*Apr 8 14:06:22 UTC: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
*Apr 8 14:06:23 UTC: %SMART_LIC-6-REPORTING_REQUIRED: A Usage report acknowledgement will be required in 363 days.
*Apr 8 14:06:58 UTC: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/2, interfaces disabled
*Apr 8 14:06:58 UTC: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/2 is DOWN
*Apr 8 14:06:58 UTC: %SPA_OIR-6-OFFLINECARD: SPA (NIM-LTEA-EA) offline in subslot 0/2
*Apr 8 14:07:01 UTC: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type tacacs+ (UNKNOWN)
*Apr 8 14:07:25 UTC: %SPA_OIR-6-ONLINECARD: SPA (NIM-LTEA-EA) online in subslot 0/1
*Apr 8 14:07:50 UTC: %IOSXE_OIR-6-REMSPA: SPA removed from subslot 0/1, interfaces disabled
*Apr 8 14:07:50 UTC: %CELLWAN-2-MODEM_DOWN: Modem in slot 0/1 is DOWN
*Apr 8 14:07:50 UTC: %SPA_OIR-6-OFFLINECARD: SPA (NIM-LTEA-EA) offline in subslot 0/1
*Apr 8 14:07:59 UTC: %SMART_LIC-3-COMM_FAILED: Communications failure with the Cisco Smart License Utility (CSLU) : Unable to resolve server hostname/domain name
*Apr 8 14:08:21 UTC: %AAA-3-BADSERVERTYPEERROR: Cannot process accounting server type tacacs+ (UNKNOWN)
*Apr 8 14:08:21 UTC: %AAA-3-DROPACCTFAIL: Accounting record dropped, send to server failed: system
*Apr 8 14:08:21 UTC: %SNMP-5-COLDSTART: SNMP agent on host ciscoLTE is undergoing a cold start
*Apr 8 14:08:22 UTC: %SYS-6-BOOTTIME: Time taken to reboot after reload = 535 seconds
ciscoLTE#sho facility-alarm status
System Totals Critical: 2 Major: 0 Minor: 0
Source Time Severity Description [Index]
subslot 0/1 Apr 08 2021 14:07:50 CRITICAL Active Card Removed OIR Alarm [0]
subslot 0/2 Apr 08 2021 14:07:11 CRITICAL Active Card Removed OIR Alarm [0]
GigabitEthernet0/0/1 Apr 08 2021 14:06:00 INFO Physical Port Administrative State Down [2]
xcvr container 0/0/2 Apr 08 2021 14:06:00 INFO Transceiver Missing [0]
What license is the router running on?
sh license status
Listed below are the outputs of sh license status and sh license summary. Thanks again for the help.
ciscoLTE#sh license status
Utility:
Status: DISABLED
Smart Licensing Using Policy:
Status: ENABLED
Data Privacy:
Sending Hostname: yes
Callhome hostname privacy: DISABLED
Smart Licensing hostname privacy: DISABLED
Version privacy: DISABLED
Transport:
Type: cslu
Cslu address: <empty>
Proxy:
Not configured
Policy:
Policy in use: Merged from multiple sources.
Reporting ACK required: yes (CISCO default)
Unenforced/Non-Export Perpetual Attributes:
First report requirement (days): 365 (CISCO default)
Reporting frequency (days): 0 (CISCO default)
Report on change (days): 90 (CISCO default)
Unenforced/Non-Export Subscription Attributes:
First report requirement (days): 90 (CISCO default)
Reporting frequency (days): 90 (CISCO default)
Enforced (Perpetual/Subscription) License Attributes:
First report requirement (days): 0 (CISCO default)
Report on change (days): 0 (CISCO default)
Export (Perpetual/Subscription) License Attributes:
Miscellaneous:
Custom Id: <empty>
Usage Reporting:
Last ACK received: <none>
Next ACK deadline: Apr 06 18:33:54 2022 UTC
Reporting push interval: 30 days
Next ACK push check: <none>
Next report push: Apr 08 14:07:50 2021 UTC
Last report push <none>
Last report file write: <none>
Trust Code Installed: <none>
ciscoLTE#sh license summary
License Usage:
License Entitlement Tag Count Status
appxk9 (ISR_4331_Application) 1 IN USE
uck9 (ISR_4331_UnifiedCommun...) 1 IN USE
securityk9 (ISR_4331_Security) 1 IN USE
Can you downgrade to 17.3.X?
Please use Install Mode.
Downgraded from IOS XE 17.04.1b to 17.03.03
Now when I type "sh facility-alarm status", I see the following
GigabitEthernet0/0/1       Apr 13 2021 14:18:32            INFO                Physical Port Administrative State Down [2]
xcvr container 0/0/2        Apr 13 2021 14:18:32            INFO                Transceiver Missing [0]
NIM subslot 0/1               Apr 13 2021 14:18:17            MAJOR            Boot state [1]
NIM subslot 0/2               Apr 13 2021 14:18:17            MAJOR            Boot state [1]
Figuring the LTE cards which are in subslot 0/1 and 0/2 are ready to boot up based on the output. I typed in "hw-module subslot 0/1 reload" and I got the following result %Command cannot be executed. Card in subslot 0/1 is missing
So I am back to square one ...
Raise a TAC Case.
Hi Leo,
Thanks for all the help, much appreciated.
-Amrit
marce1000
 - Check compatibility notes and required software version(s) from this document :
            https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
 M.
