Help Me 2950T
julihato
Can 5 switches perform daisy-chain design?
2950T
2950T --
2950T |
2950T | ---> 1000BaseT
2950T |
2950T --
Consider above design Is it work?
Thank YOu Hato
scorpions
yes !it is.if daisy-chain become a loop.stp will down a connection
amowat
Yes, daisy chaining like this is acceptable. If you wanted to get the absolute best performance, you would attach them all to one 'aggregation' switch, but as it is, if you are using the 1000BaseT ports, you'll have no real latency.
Halo,
What's the "Stackable" and "Standalone" verbs stand for in the Catalyst switches.
Thank YOu
HATO
scottmac
Level 10
Level 10
It may work, but it really poor design.
It may also NOT work, depending on the traffic loads of the various segments. At potentailly 700 meters distance, plus latencies, IMHO, the reliability would be at risk.
Are you going to run those redundant links by a diverse path, or just using them for bandwidth aggregation? You should not assume that traffic on the two (or more) ports is exactly split ... it usually isn't.
If the redundant links are not using diverse paths, then you have many single-points-of-failure.
IMHO, bad design, and should be avoided if at all possible.
"Stackable" means the switches can be ganged together and managed as if it were one logical switch.
Good Luck
Scott
