Help on VxLAN EVPN Configuration on Catalyst 9500-32C
Aaron D
Attempting to configure VxLAN EVPN on a pair of Catalyst 9500-32C's for a Proof of concept. No joy so far. Been referencing these links:
https://community.cisco.com/t5/data-center-blogs/vxlan-evpn-configuration-example-n9k-p2p/ba-p/3663830
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9500/software/release/16-10/configuration_guide/lyr2/b_1610_lyr2_9500_cg/configuring_vxlan_bgp_evpn.html
BRKDCT-2949.
Any suggestions?
Main goal is to bridge a single VLAN and have 2 hosts communicate across the VTEPs.
19 Replies 19
yes i think they are layer 3 interface, but you could use loopback address. it does not matter
Hi Everyone,
I'm also trying to achieve this configuration. Has anyone ever run into the following error when trying to configure the NVE interface?
% Can't configure L2DP VNIs on NVE interface with CP or CP VNI configured
More specifically I get this when trying to configure the "member vni 11001 ingress-replication"
Tim
Never received these warnings I thing something is different in your setup
Figured it out - Catalyst 9K is the minimum hardware platform I was on a 3650 with DNA Advantage Licensing and 16.12.2. Once I swapped to 9300 - worked straight away.
Happy to help
