help !! router can't entry via super terminal ?what's wrong ?
henre2005
My cisco 2611 router is running nomally ,via tftp may entry ,but cann't entry via super terminal of computer ?
What's wrong ?
spremkumar
Level 9
Level 9
hi
You mean Superterminal here as the telnet application or using hyperterminal connection ??
do revert how ur using or steps used to access via superterminal..
regds
desai.jaideep
Level 5
Level 5
Which OS r u using.Can u tell the exact software(ought to be HyperTerminal in there)
Are you trying to get in through console?
JD
