12-20-2019 09:28 AM
So I have managed to scrounge together some items to start a home lab for practice. The items I have are as follows:
With what is listed, is this a decent beginning to a lab? I'm studying for my CCENT right now, and would hope to build onto this setup a bit later. What would be some suggestiosn on to add or take away from what I have now?
Any advice is helpful.
12-20-2019 09:33 AM
That is good to start, eventually, you learn, what you need when you learning new stuff and advanced technology to add new devices.
otherwise you will never going to start, if you keep looking to add more devices,
begin with what you have
move to next level, personally once you hands on some physical kit
next level everything move to virtual like GNS3 / EVE-NG / VIRL
04-07-2021 07:01 AM
How did you connect your 3750 Catalyst to the router 1941?
