How do I delete flash on a router in rommon?
chris morris
olorunloba
Level 5
Level 5
I think you should use the xmodem. Xmodem from Rommon will delete all the previous images, rather than add to it. So, if the flash is big enough to take the new file, then it should work. I'm not sure there is any command to delete files from flash from within Rommon.
On second thoughts, you cannot use xmodem for a remote router as you need to be connected to the console.
