02-12-2002 12:52 PM - edited 03-01-2019 08:27 PM
I am currently using Route maps and prepend statements, but is there a way that I can truly load balance with BGP? How do the ISP's do it?
Thanks in advance,
Jpoulos
CCNP, MCSE
02-12-2002 01:15 PM
BGP is not designed to load balance traffic. You can load balance between multiple circuits between the same two router's, but not to different routers.
Example:
Router A has three DS3's to Router B
You setup three static routes from Router A to Router B's loopback address, and vice versa. You then build the BGP session to the loopbacks. This will balance the traffic.
02-19-2002 05:56 PM
Look for ibgp multipath for bgp load balancing. It doesn't sound like this is what you are trying to do, though....
Russ
02-20-2002 12:25 AM
You can set LocalPreference value of the routing update to archive outgoing traffic load balance. Also you can set metric to the traffic comming to the AS.
02-21-2002 11:41 PM
hi,
as such bgp doesnt do any load balancing. what you can do is add 2 static routes thru the different interfaces thru wehich u connect to your upstream provider. then you can instruct the provider also to do the smae at his end. your load will be balanced then.
thanks,
ramesh
