How to fix vlan's rate in a trunk ?
LucBourget
Our configuration : 1 x 2950G-48 with uplink 1 Gb/s
There are 3 vlans.
--> uplink is configure as a trunk.
We want that vlan3 don't use more than 100 Mb/s in the uplink.
Is it possible to do this ?
Thanks for your help,
LB.
pflunkert
Level 4
Level 4
yes it should be possible. You must mark all traffic in the vlan 3 (with dscp 10 for example) and drop the exceeded traffic through a policy map:queue.
Switch(config)# policy-map flow1t
Switch(config-pmap)# class ipclass1
Switch(config-pmap-c)# police 10000000 8192 exceed-action dscp 10
Switch(config-pmap-c)# exit
Switch(config-pmap)# exit
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# switchport mode access
Switch(config-if)# service-policy input flow1t
The policy works only incoming, but when you enable it on both sites it should works.
The link will help you with the configuration:
http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00802c31e8.html#wp1083017
Peter
