how to load ios into 3745 if flash ios accidently erased
ciscoforum
how to load ios into 3745 if flash ios accidently erased? Router went into rommon mode. Thanks
dean.pecorari
if you dont have a compact flash slot you could always use x-modem from hyperterminal to download
an image
I dont think the 37xx allow you to change the baud rate ( I could be wrong)...Xmodem at 9600 baud can take hours to load a 20 MB + IOS image. Your best bet is to download a 6 or 7 Meg IP ONly feature set IOS and first upgrade the router using XModem and once you have done this upgrade, you should be able to download your required IOS (20+ MB in size) using TFTP. (copy tftp flash command).
Hope that helps!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
cannot type copy tftp command.
switch: copy
usage: copy [-b <buffer_size>] <src_file> <dst_file>
switch: copy tftp: flash:
tftp:: no such device
