HSRP issues with Bridging
l-harvey
I have connected a 6513 to a 5513, no problems. But when I enable HSRP between the RSM and the MSFC the I have issues with the Vlans with bridge-group 1 set up. ie,
RSM 5513
interface Vlan1
description Management and Trunking
ip address 10.1.1.1 255.255.0.0
standby 1 ip 10.1.1.3
standby 1 priority 110
standby 1 preempt
interface Vlan8
description Education
ip address 10.8.1.1 255.255.0.0
ipx network 8B encapsulation SAP
no ipx pad-process-switched-packets
standby 1 ip 10.8.1.3
standby 1 preempt
bridge-group 1
6513 IOS
interface Vlan1
ip address 10.1.1.2 255.255.0.0
no ip redirects
no ip proxy-arp
no logging event link-status
interface Vlan8
ip address 10.8.1.2 255.255.0.0
no ip redirects
shutdown
bridge-group 1
Vlan 1 ok but HSRP in vlan 8 just flaps HELP
6 Replies 6
not sure if this is a typo, but your VLAN 8 interface on your 6513 is in ´shutdown´ state. Can you try and enable it (no shutdown) and see if that makes a difference ?
Georg
www.solutionfinders.nl
Sorry the reason it's in shutdown is because it flaps.
I have more than these two vlans. The config was an example. I can only have one vlan with Bridging enables on both devices, as soon as I add a second vlan with bridging flapping starts. This seems to be a STP issue but with two 5513 and RSMs no issues. Only since I installed the 6513 as a replacement for one of the 5513s. I haven't played with the STP default options as this is where my knowledge is limited.
Example of error message when two vlans have bridging eabled
Sep 19 13:10:42.725 BST: %DUAL-5-NBRCHANGE: IP-EIGRP 1: Neighbor 10.8.1.2 (Vlan8) is down: peer restarted
Sep 19 13:10:43.065 BST: %DUAL-5-NBRCHANGE: IP-EIGRP 1: Neighbor 10.8.1.2 (Vlan8) is up: new adjacency
IP and IPX only vlans no issues
The reason is the standby Group number being the same on the VLAN interfaces. You are limited with the number of MAC addresses available on the Cat6000 Sup2/MSFC2 you have. If you do a show interfaces on the 6000 you will see that they all have the same MAC address and you can't change them. The same logic applies to HSRP; identical numbered HSRP groups use the same virtual MAC address so bridging on VLAN interfaces with the same HSRP group number will generate errors.
http://www.cisco.com/en/US/partner/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e6cf.html
http://www.cisco.com/en/US/partner/products/hw/switches/ps700/products_qanda_item09186a008011c6bb.shtml
Andy
My CCo will not access these short cuts.
But the MSFC 2 will only support 16 standby groups I have over 35 Vlans.
Kevin Dorrell
Level 10
Level 10
You have both VLANs using the same standby group, group 1. I don't know whether this is really the problem, by I have always configured each VLAN on a different standby group. Try changing all the config lines for VLAN8 to "standby 2 ...", or even "standby 8 ... " if you want to use clearer numbering.
Kevin Dorrell
Luxembourg.
The MSFC on the 6513 will only support maximum of 16 standby groups I have over 35 Vlans.
I have noticed that the bridge 1 protocol on the 5513 is set to ieee and the 6513 is set to vlan-bridge due to the 6513 not supporting ieee I will try the next downtime window to change the protocol on the 5513 to vlan-bridge.
