I need E1 interface card for my 7204 router
sam_a_a_oladele
Please is anyone there knows where I can get E1 interface card for 7204 router? If yes, can you tell me where? I will also need the part number of the interface card as well as how much it is going for.
Thank you.
sam_a_a_oladele
I have PRI 2CE1B, can it work with 7204 router?
averzosa
Hi Sam,
Good Day! :-)
Are you looking for E1 PRI adapters. Here are some of the E1 port adapters that 7204 router supports.
*PA-MC-2E1/8E1 PRI
*PA-2CE1
*PA-MC-8TE1+
You may also refer to the links below for more information about the above mentioned port adapters.
PA-MC-2E1/8E1 PRI Port Adapter Installation and Configuration
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7505/portadpt/multi_ch/5083e1p/index.htm
PA-2CE1 Channelized E1 Port Adapter Installation and Configuration
http://www.cisco.com/univercd/cc/td/doc/product/core/cis7505/portadpt/multi_ch/pa_c2ce1/index.htm
8-Port Multichannel T1/E1 8PRI Port Adapter Installation and Configuration
http://www.cisco.com/univercd/cc/td/doc/product/core/7200vx/portadpt/multicha/8port_t1/index.htm
I hope these are the information that you are need.
Best Regards,
Ansley R. Verzosa
Try PA-4E1G/75 (75 ohms) or PA-4E1G/120 (120 ohms) if you are not in need of a channelised interface.
