04-28-2003 05:42 AM - edited 03-02-2019 06:57 AM
I have a 2meg internet connection presented as x21 on a 3600 router my provider is going to increase this by another 2 Meg. To do this they are going to present another 2 meg on an additional x21 cable. My problem is i use IP unnumbered for the ip address of the existing interface, can i keep this when i effectively have two internet connections on the router. Does someone a smarter way of configuring a router for two x21 internet connections?
04-28-2003 07:19 AM
If you are using PPP encapsulation, you can configure multilink on the two interfaces and give ip unnumbered command for the multilink interface.
Chk this out:
http://www.cisco.com/warp/public/793/access_dial/pppmultilink.html
04-29-2003 12:42 AM
thanks for the info, i will ask the internet provider if they can accomodate ppp multilink at their end
