Input Error on WAN Circuits
jason.poon
Would like to know the following:
3867 input errors, 49 CRC, 0 frame, 0 overrun, 0 ignored, 474 abort
2857253 packets output, 677085019 bytes, 0 underruns
Does it means that the circuit that the telco is providing us has errors on it? Pls help
Have been receiving Lots of Input Errors and CRC Errors for the last two weeks! Pls adv.
15 Replies 15
hi
we had faced a similar problem at one of our sites. we had a burt test done from end to end and it showed us a clean circuit. we did try changing the clock but it gave us temporary relief. my strong suspicion is that it is a problem with the cabling. check the route the cables have taken and also check if any new electric wiring has been done.
you could also try the no crc option
