Interface Problem HELP..!
Hi, I get this output and I worry 'cause I see a lot of Collisions. I am trying to figure out why it is happening so can you give me any hint to fix this problem. It will be appreciate:
Thanks a lot
Ethernet3/0 is up, line protocol is up
Hardware is AmdP2, address is 0006.28ac.b6f0 (bia 0006.28ac.b6f0)
Description: ENLACE JOSE-TAEJ
Internet address is 167.175.XXX.XXX/24
MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
reliability 252/255, txload 9/255, rxload 1/255
Keepalive set (10 sec)
Last input 00:00:01, output 00:00:00, output hang never
Last clearing of "show interface" counters 3w3d
Queueing strategy: fifo
Output queue 0/40, 0 drops; input queue 0/75, 0 drops
5 minute input rate 43000 bits/sec, 40 packets/sec
5 minute output rate 362000 bits/sec, 48 packets/sec
63633860 packets input, 2953326560 bytes, 0 no buffer
Received 2783968 broadcasts, 0 runts, 0 giants, 0 throttles
73 input errors, 73 CRC, 71 frame, 0 overrun, 0 ignored
67426757 packets output, 2044491211 bytes, 0 underruns(251948/145126/0)
867630 output errors, 397074 collisions, 863606 interface resets
0 babbles, 867631 late collision, 314972 deferred
0 lost carrier, 0 no carrier
FastEthernet0/0 is up, line protocol is up
Hardware is AmdFE, address is 0006.28ac.b6c0 (bia 0006.28ac.b6c0)
Description: RED LAN JOSE
Internet address is XXX.XXX.XXX.XXX/23
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
Half-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:00, output 00:00:00, output hang never
Output queue 0/40, 0 drops; input queue 0/75, 48822 drops
5 minute input rate 661000 bits/sec, 175 packets/sec
5 minute output rate 645000 bits/sec, 149 packets/sec
181857038 packets input, 3358605878 bytes
Received 9629171 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
182533535 packets output, 3842462072 bytes, 0 underruns(134903/233069/0)
0 output errors, 367972 collisions, 0 interface resets
0 babbles, 0 late collision, 431672 deferred
FastEthernet2/0 is up, line protocol is up
Hardware is AmdFE, address is 0006.28ac.b6e0 (bia 0006.28ac.b6e0)
Description: RED LAN BITOR-JOSE
Internet address is XXX.XXX.XXX.XXX/24
reliability 255/255, txload 3/255, rxload 1/255
Half-duplex, 10Mb/s, 100BaseTX/FX
Last input 00:00:05, output 00:00:01, output hang never
5 minute input rate 18000 bits/sec, 2 packets/sec
5 minute output rate 128000 bits/sec, 4 packets/sec
18937196 packets input, 551573510 bytes
Received 432197 broadcasts, 0 runts, 0 giants, 0 throttles
12 input errors, 12 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog
21194159 packets output, 3783328332 bytes, 0 underruns(103346/137869/0)
0 output errors, 241215 collisions, 0 interface resets
0 babbles, 0 late collision, 104084 deferred
5 Replies 5
Georg Pauwen
collisions are usually caused by speed and/or duplex settings mismatches. Make sure that whatever is connected to your (Fast)Ethernet ports has the same settings. A good strategy to find out the settings of the connected devices is to set your ports to autonegotiate mode, e.g.:
interface FastEthernet0/0
speed auto
duplex auto
and then check what is negotiated with the ´show interfaces FastEthernet0/0´ command. After you have verified the settings, you might want to fix the settings in your configuration, e.g.:
speed 100
duplex full
HTH,
Georg
I have verified the spped and duplex but the problem still there. Any other suggestion?
Why the interface resets ...?
Collisions can also be caused by bad ethernet cables. Replace the cabling between devices with known good cables.
grantlewis
Community Member
All three of your interfaces are set at half duplex.
is Ethernet 3/0 connected on the other end to a device that is:
duplex = halfduplex
speed = 10 Mb/s ?
is FastEthernet 0/0 connected on the other end to a device that is:
duplex = halfduplex
speed = 100 Mb/s ?
is FastEthernet 2/0 connected on the other end to a device that is:
duplex = halfduplex
speed = 10 Mb/s ?
If you have access to CCO, paste your output into the output interperter tool, which will "troubleshoot" your interfaces for you and provide some links like the one below to understand what is going on.
http://www.cisco.com/univercd/cc/td/doc/cisintwk/itg_v1/tr1904.htm
glen.grant
Collisions in a half duplex environment are not inherently bad , it is doing it's job . The main problem is how many you are getting to total traffic transmitted and recieved , anything under 10 percent is probably not a problem . If these links are being driven hard ,which isn't very hard on 10/half links you are going to see considerable collisions, runts, crcs etc... You need to look at the traffic patterns and utilization on the links to see if this is your problem if all your Layer 1 stuff checks out . If utilization is continually high then you need to consider upgrading all your links to 100/full duplex which will eliminate this problem totally . Utilization of above 30 % will cause all kinds of slowdowns and user problems in a half duplex environment .
