InterVlan routing on cisco 2811
edjbartos
I am trying to do intervlan routing on a cisco 2811 fitted with a HWIC 4ESW card. I have created 3 vlans each with a different subnet ip address. Can anyone give me advice on how i would go about doing intervlan routing? Thanks in advance.
20 Replies 20
what does a 'show vlan' say ? Is Vlan 4 actually existing in your VLAN database ?
Also, can you post your configuration here again, as a reply to a post rather than as an attachment ?
GNT
edjbartos
copy of my config and show vlan
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0/0$$ES_LAN$$FW_INSIDE$
ip address 82.110.135.1 255.255.255.128
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/1
description $ES_WAN$$FW_OUTSIDE$
ip address 217.205.255.10 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
ip route-cache flow
duplex auto
speed auto
no mop enabled
interface FastEthernet0/0/0
interface FastEthernet0/0/1
switchport access vlan 4
spanning-tree portfast
interface FastEthernet0/0/2
switchport access vlan 2
interface FastEthernet0/0/3
switchport access vlan 3
interface Vlan1
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip route-cache flow
interface Vlan2
ip address 10.0.0.50 255.0.0.0
interface Vlan3
ip address 172.20.
interface Vlan4
ip address 172.23.3.100 255.255.0.0
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip http server
ip http authentication local
ip http timeout-policy idle 5 life 86400 requests 10000
ip nat inside source list 1 interface FastEthernet0/1 overload
logging trap debugging
access-list 1 remark INSIDE_IF=FastEthernet0/0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 82.110.135.0 0.0.0.127
no cdp run
control-plane
banner login ^CAuthorized access only!
Disconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
scheduler allocate 20000 1000
end
netgate03#netgate03#sh vlan-switch
VLAN Name Status Ports
1 default active Fa0/0/0
2 VLAN0002 active Fa0/0/2
3 VLAN0003 active Fa0/0/3
4 VLAN0004 active Fa0/0/1
5 VLAN0005 active
1002 fddi-default active
1003 token-ring-default active
1004 fddinet-default active
1005 trnet-default active
the config looks ok...
What does a 'route print' on your laptops show ? Can you post the output from both laptops, as well as the output of 'ipconfig' from both laptops ?
GNT
edjbartos
Vlan 4
>route print
Interface List
0x1 ........................... MS TCP Loopback interface
0x2 ...00 0e 35 80 09 fa ...... Intel(R) PRO/Wireless 2200BG Network Connection
- Packet Scheduler Miniport
0x3 ...00 0d 60 7a e4 5d ...... Intel(R) PRO/1000 MT Mobile Connection - Packet
Scheduler Miniport
Active Routes:
Network Destination Netmask Gateway Interface Metric
127.0.0.0 255.0.0.0 127.0.0.1 127.0.0.1 1
172.23.0.0 255.255.0.0 172.23.3.101 172.23.3.101 20
172.23.3.101 255.255.255.255 127.0.0.1 127.0.0.1 20
172.23.255.255 255.255.255.255 172.23.3.101 172.23.3.101 20
224.0.0.0 240.0.0.0 172.23.3.101 172.23.3.101 20
255.255.255.255 255.255.255.255 172.23.3.101 172.23.3.101 1
255.255.255.255 255.255.255.255 172.23.3.101 2 1
Persistent Routes:
None
C:\Documents and Settings\eddieb>ipconfig
Windows IP Configuration
Ethernet adapter Wireless Network Connection:
Media State . . . . . . . . . . . : Media disconnected
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . :
IP Address. . . . . . . . . . . . : 172.23.3.101
Subnet Mask . . . . . . . . . . . : 255.255.0.0
Default Gateway . . . . . . . . . :
Vlan 2
>route print
Interface List
0x2 ...00 09 6b d0 1d 0d ...... Intel(R) PRO/100 VE Network Connection - Packet
Scheduler Miniport
0x3 ...00 0d 54 99 2b 4a ...... 3Com 3CRPAG175 Wireless LAN PC Card - Packet Sch
eduler Miniport
Active Routes:
10.0.0.0 255.0.0.0 10.0.0.51 10.0.0.51 20
10.0.0.51 255.255.255.255 127.0.0.1 127.0.0.1 20
10.255.255.255 255.255.255.255 10.0.0.51 10.0.0.51 20
224.0.0.0 240.0.0.0 10.0.0.51 10.0.0.51 20
255.255.255.255 255.255.255.255 10.0.0.51 10.0.0.51 1
255.255.255.255 255.255.255.255 10.0.0.51 3 1
Persistent Routes:
None
C:\Documents and Settings\administrator.FLLP>ipconfig
IP Address. . . . . . . . . . . . : 10.0.0.51
Subnet Mask . . . . . . . . . . . : 255.0.0.0
Ethernet adapter Wireless Network Connection 4:
You need default a gateway configured on each laptop.
mmoris hit it on the head , you cannot get off your attached subnet with a default gateway on each user nic card . The gateway will be the defined router address for each subnet.
