IOS upgrade problems using Cisco7206
mmartel
Hello:
I have a 7206 (NPE 200), it has 128 MBDRAM and 16MB flash PCMCIA running IOS ipplus 122.23. I need IOS 12.3.10 Service Provider. I tried to use copy tftp slot0, slot1 but these slots are not available when I use ATA PCMCIA, I burned IOS into a 48 MB ATA PCMCIA using copy tftp disk0 but when I reboot router the IOS does not work, router take IOS from bootflash
Please, could you tell me to solve this problem?
s.conway
did you update the boot statement so the router would boot from slot0 and not flash
example
boot system flash slot0:c7200-js-mz.121-14.E5.bin
Hello:
I configure
boot system disk0:c7200-p-mz.123.10a.BIN
but Router did not charge this IOS, Router used flashboot IOS
when I use slot0 or slot 1 It does not work too
