11-21-2002 01:23 AM - edited 03-02-2019 03:03 AM
hi,
is it possible to use route-map to set the ip-prec-bit in the following way:
route-map set_ip_prec permit 10
match ip address voip
set ip precedence critical
route-map set_ip_prec permit 20
match ip address premium
set ip precedence flash-override
route-map set_ip_prec permit 30
match ip address gold
route-map set_ip_prec permit 40
match ip address silver
set ip precedence immediate
route-map set_ip_prec permit 50
set ip precedence priority
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.20.205.250 255.255.255.0
ip policy route-map set_ip_prec
(and of course i have acl´s which match the traffic)
i did some testing and saw that as long as i had cef enabeld the route-map did not work.
as i disabled cef - everything was ok - is this "normal" ???
thanks for an answer
11-23-2002 06:28 PM
Actually I would use "service-policy input" rather than "ip policy" since the ip policy is usually used for policy-based routing, whereas setting QoS works best with "service policy".
11-24-2002 11:28 PM
hi,
thanks for an answer!
the problem is that i have an ios which is not able to set the ip-prec bit
with the "set ip prec - Command .
But the ip policy-Command is ok.
So the only question is:
Is cef and "ip-policy" to set the prec-bit possible ??
thanks for an answer !
