IP Routing between two networks
imuonagor
I have a Cisco 2600 with an ip addr of 66.178.47.99 255.255.255.248 configured on ethernet 0/0, while ethernet0/1 has an address of 10.1.180.102 255.255.252.0
my problem is that while i can ping a vsat modem with ip address 66.178.47.97 connected to e0/0 from the router, i am unable to ping same from a PC with ip address of 10.1.180.103 (connected to e0/1).
from the same router i can also ping the PC.
Thanks in advance!
5 Replies 5
svermill
Level 4
Level 4
Did you set the default gateway in your PC to 10.1.180.102?
Thanks, i tried it over the night but got the same results...
So i configured another PC with 66.178.47.101 and connected it to e0/0 66.178.47.98 and tried to ping from the 1st PC across to the second and to my surprise it replied. but i just removed the cross over cable from the PC and inserted it into the VSAT modem 66.178.47.97 but it began to time out.
I also changed the gateway on my 10.1.180. PC to 66.178.47.98 but the modem still kept mute.
could it be the modem or is there any other thing i should do?
thanks a million 4 ur help.
Unfortunately, I don't know anything about your modem. Is there anything that is configurable other than the IP itself? Is it yours or a service provider's?
are u able to ping e0/0 interface from PC .
Do a traceroute to the IP os ur modem .
Also can u configure IP on the modem with some GUI .
What is the gateway on modem .
regards,
Hey! Thank you all for running to my aid!!! Sorry, the problem is actually from the service provider!
Actually while i was still on it i configured a PC with the same ip address as the modem and i could ping it. And when i put the same cable to the modem it failed to reply, so i called the service provider and they told me they had disabled routing on the modem for security purposes.
Thanks a million for your support...
