01-05-2005 12:17 PM - edited 03-02-2019 08:54 PM
Does anyony know what are port 2228, 67, 200, and 55424 on Catalyst 4507?
4507#sh ip sockets
Proto Remote Port Local Port In Out Stat TTY OutputIF
17 192.168.4.182 514 192.168.4.1 53120 0 0 0 0
17 192.168.4.183 49 192.168.4.1 49 0 0 9 0
17 --listen-- 192.168.4.1 2228 0 0 89 0
17 --listen-- 192.168.2.1 67 0 0 489 0
17 0.0.0.0 123 192.168.4.1 123 0 0 1 0
88 0.0.0.0 0 192.168.4.1 200 0 0 0 0
17 192.168.4.182 4619 192.168.4.1 161 0 0 1 0
17 0.0.0.0 0 192.168.4.1 162 0 0 9 0
17 0.0.0.0 0 192.168.4.1 55424 0 0 9 0
17 172.24.9.44 514 192.168.4.1 50038 0 0 0 4
Thank you.
01-05-2005 07:13 PM
hi
these are the 2 general applications which i could find out associated with 2 of the port nos as mentioned in ur post...
bootps 67/tcp Bootstrap Protocol Server
bootps 67/udp Bootstrap Protocol Server
bootpc 68/tcp Bootstrap Protocol Client
bootpc 68/udp Bootstrap Protocol Client
src 200/tcp IBM System Resource Controller
src 200/udp IBM System Resource Controller
regds
01-06-2005 04:10 AM
Hi Edwin,
Thank you for your response. Why is port 67 listed as "listen" on a remote device? Is this an illegal port and activity?
Best regards,
Santi
