IPSEc not working with VTI interface
hemanths6869
Dear All,
  I had tried IPsec with fast Ethernet 0/1 it works fine but when i tried to map same ipsec crypto to tunnel1 {VTI} interface IPsec not working.
 My remote Site checks for source IP of fast Ethernet 0/0 {Proxy ID in Juniper}
 I tried to MAP crypto map to tunnel 1 interface but it not work
 below here is my config {Peer IP, Pre-Shared Key, Names removed for security}
PuTTY log 2014.06.26 16:46:48
sh run
Building configuration...
Current configuration : 1556 bytes
version 12.4
hostname xyz
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
username xyz password 0 xyz
crypto isakmp policy 1
 encr 3des
 authentication pre-share
group 5
crypto isakmp key MYKEY@123 address XX.XX.XX.XX
crypto ipsec transform-set ABC esp-3des esp-sha-hmac
crypto ipsec profile Tunnel
crypto ipsec profile tunnel
  set transform-set ABC
set pfs group5
crypto map ABC 1 ipsec-isakmp
set peer XX.XX.XX.XX
match address 108
 interface Tunnel1
 description Branch_End
ip unnumbered FastEthernet0/1
 tunnel source FastEthernet0/1
 tunnel destination XX.XX.XX.XX
  tunnel mode ipsec ipv4
 tunnel protection ipsec profile tunnel
 interface FastEthernet0/0
 description LAN
 ip address 10.1.10.1 255.255.255.0
 duplex auto
 speed auto
interface FastEthernet0/1
 ip address 192.168.1.2 255.255.255.0
 duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no fair-queue
 clock rate 2000000
interface Serial0/0/1
no ip address
shutdown
 clock rate 2000000
 ip forward-protocol nd
 ip route 0.0.0.0 0.0.0.0 Tunnel1
ip http server
no ip http secure-server
 access-list 108 permit ip 10.1.10.0 0.0.0.255 any
control-plane
 line con 0
line aux 0
line vty 0 4
login
scheduler allocate 20000 1000
 end
MYROUTER#
MYROUTER#sh crypto session
Crypto session current status
Interface: tunnel 1
Session status: DOWN-NEGOTIATING
Peer: XX.XX.XX.XX port 500
  IKE SA: local 192.168.1.2/4500 remote 223.30.69.138/4500 Active
  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0
        Active SAs: 2, origin: crypto map
MYROUTER#
 Because of  IPSEC FLOW: permit ip 0.0.0.0/0.0.0.0 0.0.0.0/0.0.0.0 IPsec not up Remote Device checks for IPSEC FLOW: permit ip 10.1.10.0/255.255.255.0 0.0.0.0/0.0.0.0
 Please help me thanks in advance.
Hemant
bhnegi
Hi Hemant,
Can you put a  route to the tunnel destination and see if it helps.
Best Regards,
Bheem
rus-admin
Crypto map not needed, if you use ipsec vti. Need only crypto ipsec profile.
Try without crypto map.
